You can play TIDAL on your device in two ways:
From Volumio: browse and search TIDAL in
Browse→TIDAL.From the TIDAL app: pick your device as the speaker with TIDAL Connect.
You need a TIDAL subscription. TIDAL is a Premium feature: it's included on Volumio devices, and needs a Premium plan on Raspberry Pi and PC.
Connect your TIDAL account
Open your device and go to
Settings→Sources.Under
TIDAL, pressConnect.Sign in to TIDAL in the page that opens and allow access.
When you're back, TIDAL shows up in Browse.
To disconnect your account, press Logout in the same section.
Play from the TIDAL app
Connect your phone to the same network as your device.
Open the TIDAL app, start a song, tap the devices button and choose your device.
Settings → Sources → My music → Music sources and check that Tidal connect is on.Choose the sound quality
Go to
Settings→Sources, belowTIDAL.In
Sound quality, choose the quality you want, orHighest possibleto always get the best one.Press
Save.
Sound quality only applies when you play from Volumio. With TIDAL Connect, choose the quality in the TIDAL app's settings.
In the same section, Number of search results sets how many results TIDAL shows when you search.
Troubleshooting
The quality is lower than expected
Tap the quality badge on the player: Audio quality shows what your device is actually playing.
Check that your TIDAL plan includes the quality you want.
Playing from Volumio: check
Sound qualityinSettings→Sources, and pressSave.Playing from the TIDAL app: check the streaming quality in the TIDAL app's settings.
Not every song is available in Hi-Res: the quality depends on each song.
Your device or DAC may not support the highest qualities: in that case, the music plays at the best quality they support.
For other issues, such as TIDAL not showing up or not signing in, see Streaming service issues.
