Your device gets updates from the stable channel: versions that have been fully tested. On the beta channel, you get new versions earlier, before they're released to everyone.
Switch to the beta channel
On a computer on the same network as your device, open a web browser.
Type your device's name followed by
.local/dev, for examplehttp://motivo.local/dev. If it doesn't work, use the device's IP address instead, for examplehttp://192.168.1.20/dev. To find both, see Volumio in a browser.Under
Update Channel Selection, chooseTest.In the app, open your device and go to
Settings→System, then pressCheck updatesunderSystem updatesto install the beta version.
Test again after every update: once an update is installed, the device goes back to the stable channel.Go back to the stable channel
After a beta update, your device is already back on the stable channel, and gets the next stable version as usual.
If you chose Test but haven't updated yet, go to the same page and choose Stable under Update Channel Selection.
If you report a problem while you're on a beta version, tell us in your report.
