If your music is on a NAS or a computer in your home, you can add its shared folder as a network drive. Its music then shows up in your library, together with the music on USB drives.
Network drives are in your device's Settings → Sources → Network drives.
Before you start
Your NAS or computer must be on, and on the same network as your device.
The music folder must be shared on the network, with SMB (also called CIFS, the most common one) or NFS. See your NAS's manual to turn sharing on.
Add a drive found on your network
Go to
Settings→Sources→Network drives.Under
Found on your network, find your NAS and pressUse (folder) on (NAS)for the folder with your music.If the NAS asks for a login, type its
UsernameandPasswordand pressConnect.
If your NAS isn't in the list, press Scan again, or add it by hand.
Add a drive by hand
Go to
Settings→Sources→Network drivesand pressAdd network drive.Fill in the form:
Alias: a name for the drive, for exampleMy NAS.NAS IP address: the address of your NAS or computer, for example192.168.1.20.Path: the shared folder, for exampleMusic.File share type:CIFSfor SMB shares,NFSfor NFS shares.Username (optional)andPassword (optional): the login for the NAS, if it needs one.
Press
Save drive.
The device reads the music on the drive and adds it to your library. With a big library, this can take a while.
To change or remove a drive, use the edit and remove buttons next to it.
Troubleshooting
Error when adding network drive
Check that the NAS or computer is on and not asleep.
Check
NAS IP address: it's in your router's list of connected devices, or in your NAS's settings.Check
Path: it must be the name of the shared folder exactly as your NAS shows it, including uppercase letters.Check
Username (optional)andPassword (optional): try them on a computer first. If the folder is open to everyone, leave them empty.Check
File share type:CIFSfor SMB,NFSfor NFS.Press
Save driveagain.
SMB: the drive doesn't connect with the right details
Older NAS and routers with a USB port often only support an old SMB version.
Press the edit button next to the drive and open
Advanced options.In
Mount options, typevers=1.0, orvers=2.0if that doesn't work.Press
Save changes.
NFS: the drive doesn't connect
On your NAS, check the NFS permissions of the folder: your device's IP address (or your whole network) must be allowed to read it.
Music is missing, or disappears after a restart
See Music library issues.
