Lineo5 is a low-noise linear power supply for Volumio streamers and other 5V audio devices. It replaces your device's external switching power supply and delivers a single 5V DC output. Connect it to your device with the included GX-16 to DC barrel jack cable.
Lineo5 - User manual (EN)Specifications
Output: one 5V DC output, 5A max.
Input voltage: switchable between 100-120V AC (50/60Hz) and 220-240V AC (50Hz).
Power consumption: 90W max at full output load.
Toroidal transformer with linear regulation.
Easy-to-access fuse.
Aluminum chassis with side-facing heatsinks.
Dimensions: 27 × 22.7 × 7.7 cm.
Connectivity
DC output: 2-pin GX-16 connector.
Output cable: GX-16 to 5.5 × 2.1 mm DC barrel jack, tip positive, 115 cm (about 45 in) long.
AC input connector, with a voltage selector switch on the back panel. Set it to your mains voltage before connecting to power.
Front power button and blue status LED, which lights when Lineo5 is on.
In the box
Lineo5, 4 AC cables (EU, US, UK, AU/NZ), and a 115 cm GX-16 to DC barrel jack cable (5.5 × 2.1 mm, tip positive).
Preciso, Primo V2, Primo V3, Primo Plus, Rivo, Rivo Plus.
Integro, Motivo.
