title: "Lineo5"
description: "Low-noise linear power supply for one 5V Volumio device."
url: https://help.volumio.com/en/articles/71-lineo5
collection: "User manuals"
updated: 2026-11-03
language: en
# Lineo5
![](https://staticfiles.gleap.io/ghelparticle/Z5ab3Ov43wHyIIxx4zx85OVYSXjCSzgQeYvBeM509ThwLExgPFPXdXTU6H5A5RTDNwQ6cESM9To.jpg)
Lineo5 is a low-noise linear power supply for Volumio streamers and other 5V audio devices. It replaces your device's external switching power supply and delivers a single 5V DC output. Connect it to your device with the included GX-16 to DC barrel jack cable.
[**Lineo5** - User manual (EN)](https://heyzine.com/flip-book/9687fa31fc.html)
## Specifications
-   Output: one 5V DC output, 5A max.
-   Input voltage: switchable between 100-120V AC (50/60Hz) and 220-240V AC (50Hz).
-   Power consumption: 90W max at full output load.
-   Toroidal transformer with linear regulation.
-   Easy-to-access fuse.
-   Aluminum chassis with side-facing heatsinks.
-   Dimensions: 27 × 22.7 × 7.7 cm.
### Connectivity
-   DC output: 2-pin GX-16 connector.
-   Output cable: GX-16 to 5.5 × 2.1 mm DC barrel jack, tip positive.
-   AC input connector, with a voltage selector switch on the back panel. Set it to your mains voltage before connecting to power.
-   Front power button and blue status LED, which lights when Lineo5 is on.
### In the box
Lineo5, 4 AC cables (EU, US, UK, AU/NZ), and a GX-16 to DC barrel jack cable (5.5 × 2.1 mm, tip positive).
> **Success:** Lineo5 **IS** compatible with the following Volumio devices:
> Preciso, Primo V2, Primo V3, Primo Plus, Rivo, Rivo Plus.
> **Error:** Lineo5 **IS NOT** compatible with the following Volumio devices:
> Integro, Motivo.
