Spotify comes as a plugin. Once it's installed, you can play Spotify on your device in two ways:
From the Spotify app: pick your device as the speaker, as with any Spotify Connect device.
From Volumio: browse your playlists, albums and favorites in
Browse→Spotify, once you've authorized the device.
You need a Spotify Premium account.
Install Spotify
Open your device and go to
Settings→Plugins→Available.Find
Spotifyand pressInstall.
Play from the Spotify app
Connect your phone to the same network as your device.
Open the Spotify app and start a song.
Tap the devices button at the bottom of the player and choose your device.
Authorize Spotify on your device
Authorize the device once to browse Spotify from Volumio and play without picking it in the Spotify app every time.
Go to
Settings→Plugins→Installedand press the settings button next to Spotify.Under
Spotify account, pressAuthorize.Step 1: sign in to Spotify in the page that opens.
Step 2: press
Open the approval pageand approve your device. If Spotify asks for a code, type the one shown underCode, if Spotify asks for one:.When you see
Spotify authorized, you can find your music inBrowse→Spotify.
You have 5 minutes to approve the device. The authorization stays even after a restart.
To sign out, go back to the same page and press Remove authorization.
Spotify settings
On the same page, you can also change:
Bitrate: the streaming quality, from96 kbpsto320 kbps.Device Icon: the icon your device shows in the Spotify app.Enable autoplay: plays similar songs when your music ends.
Troubleshooting
Spotify isn't in Browse
Go to
Settings→Plugins→Installedand check that Spotify is on andActive.If it's on, authorize the device.
Your device doesn't show up in the Spotify app
Check that your phone and your device are on the same network, without VPN.
Go to
Settings→Plugins→Installedand check that Spotify isActive. If it showsStopped, turn it off and on again.Close the Spotify app completely and open it again.
Restart the device.
The authorization doesn't finish
If you see Sign-in was not completed, The device was not approved in time or Authorization did not complete, press Authorize again and complete both steps within 5 minutes.
Spotify doesn't play, or stops after a few songs
Check that your Spotify plan is Premium.
Spotify plays on one device at a time for each account: if someone else uses your account on another device, playback stops on yours.
Go to
Settings→Plugins→Installedand update Spotify ifUpdateshows up.If the device uses Wi-Fi, move it closer to the router or connect it with an Ethernet cable.
If you see
Spotify is not connected, authorize the device again, or choose it in the Spotify app.
For issues common to all streaming services, see Streaming service issues.
