Lineo5 Duo is a dual-output linear power supply for Volumio electronics and other 5V audio devices. It replaces the external switching power supplies of two devices with two independent 5V outputs, for example Rivo+ and Preciso. Connect each device with one of the included GX-16 to DC barrel jack cables.
Lineo5 Duo - User manual (EN)Specifications
Output: 2 independent 5V DC outputs, 4A max each, with dedicated regulators and filtering.
Input voltage: switchable between 100-120V AC (50/60Hz) and 220-240V AC (50Hz).
Power consumption: 120W max at full output load.
Toroidal transformer with dual linear regulation.
Audio-grade low ESR capacitors, 40000µF total bulk capacitance.
Residual noise: 20µV.
Easy-to-access fuse.
Aluminum chassis with integrated heatsink.
Dimensions: 27 × 22.7 × 7.7 cm.
Connectivity
DC outputs: two 2-pin GX-16 connectors.
Output cables: GX-16 to 5.5 × 2.1 mm DC barrel jack, tip positive.
AC input connector, with a voltage selector (110V/220V) on the back panel. Set it to your mains voltage before connecting to power.
Front power button and blue status LED, which lights when Lineo5 Duo is on.
In the box
Lineo5 Duo, 4 AC cables (EU, US, UK, AU/NZ), and 2 GX-16 to DC barrel jack cables (5.5 × 2.1 mm, tip positive).
Preciso, Primo V2, Primo V3, Primo Plus, Rivo, Rivo Plus.
Integro, Motivo.
