Rivo Ultra is our flagship digital transport: a music streamer with no built-in DAC that sends a clean, low-jitter digital signal to an external DAC. Compared to Rivo Plus, it adds a 12" touchscreen, a built-in linear power supply, optical and BNC outputs, and a slot for an internal SSD to hold your music library.
Rivo Ultra - User manual (EN)Specifications
USB output for an external USB DAC, up to PCM 1536 kHz/32 bit and DSD1024 (DSD256 with multiroom on), with power filtering and volume control on compatible DACs.
I2S/DSD over HDMI digital output, up to PCM 768 kHz/32 bit and DSD1024 (DSD256 with multiroom on), with a pin assignment you can match to your DAC's brand.
AES/EBU (XLR) digital output, up to PCM 192 kHz/24 bit and DSD64 (DoP).
Coaxial S/PDIF digital outputs (RCA and BNC), up to PCM 192 kHz/24 bit and DSD64 (DoP).
2 optical S/PDIF digital outputs (TOSLINK), up to PCM 192 kHz/24 bit and DSD64 (DoP).
Femto clock (54 fs) for the built-in outputs, and a temperature-compensated clock for the USB output.
Built-in dual linear power supply with a toroidal transformer.
16 GB of internal memory, plus a slot for an NVMe SSD up to 16 TB.
12" touchscreen and a volume knob with its own display, both with adjustable brightness.
Finishes: full aluminum, or aluminum with a leather top.
Dimensions: 44 × 34 × 9 cm.
Connectivity
Gigabit Ethernet, dual-band Wi-Fi (2.4 and 5 GHz) and Bluetooth 5.0.
1 USB 2.0 port dedicated to a USB DAC.
3 USB 3.0 ports and 1 USB-C port, for USB drives, SSDs or CD drives.
AES/EBU (XLR), coaxial (RCA and BNC) and 2 optical (TOSLINK) S/PDIF digital outputs.
I2S/DSD over HDMI digital output, for an external DAC.
HDMI output to show the Volumio interface on a TV or monitor, up to 4K/60 fps.
12V trigger output (3.5 mm jack), to switch your other components on and off together with Rivo Ultra.
IR receiver, for the included Volumio Remoto remote control.
AC power input (IEC C13), 115–230 V, with a voltage selector and 2 fuses.
In the box
Rivo Ultra, Volumio Remoto, a Wi-Fi antenna and the power cord.
