Remoto is our infrared remote control, with a solid aluminium body. Use it to control the volume, input selection, playback and DAC filter settings of compatible Volumio devices.
Remoto - User manual (EN)Specifications
Aluminium body with silver anodized finish.
Buttons: power, mute, volume down/up, play/pause, input select, previous and next track.
Power: 1 CR2032 battery. Remove the plastic strip from the battery compartment before first use.
Dimensions: 12.2 × 3.6 × 0.8 cm.
Connectivity
Infrared, with no pairing or setup needed.
In the box
Remoto and 1 CR2032 battery.
Remoto IS compatible with the following Volumio devices:
Preciso, Primo Plus.
Remoto IS NOT compatible with the following Volumio devices:
Integro, Motivo, Primo V2, Primo V3, Rivo, Rivo Plus.
