Change the volume
In the app, open your device:
On a phone: tap the player bar at the bottom to open
Listening. The volume slider andMuteare there.On wider screens, like a tablet or a computer: the volume slider is also in the player bar.
Settings → Appearance and turn on Show volume slider. If it's still not there, Mixer type is set to None: change it in Use your amplifier's volume.For devices playing together in a group, see Multiroom.
You can also change the volume from the device:
Integro: turn the right knob. Press it to mute.
Primo Plus: use the volume/mute knob on the front.
Motivo: turn the volume knob on top.
With the Remoto remote control, on compatible devices.
Volume settings
The volume settings are in Settings → Playback options → Volume options:
Mixer type: how the device changes the volume.Hardware: the volume changes without any loss in quality. Shown only when the output can change its own volume.Software: the device changes the volume itself, with some loss in quality.None: the device doesn't change the volume.
Max volume level: the highest volume the device can reach, to protect your speakers or headphones.Default startup volume: the volume when the device starts.
After changing them, press Save.
Integro handles its volume by itself, so Mixer type isn't shown.
If your amplifier or DAC has its own volume control, you can let it handle the volume. The device then always sends the full signal.
None, the device plays at full volume.Go to
Settings→Playback options→Volume options.Set
Mixer typetoNoneand pressSave.
The volume slider disappears from the app: change the volume from your amplifier or DAC.
Troubleshooting
The volume doesn't change
Go to
Settings→Playback options→Volume options.If
Mixer typeisNone, the device doesn't change the volume: pickHardwareif it's in the list, otherwiseSoftware, then pressSave.If
Mixer typeisHardwareand the volume still doesn't change, pick another option inMixer control name, then pressSave.
If you use a USB DAC and Hardware isn't in the list, see DAC issues.
The volume is too low
Go to
Settings→Playback options→Volume optionsand check thatMax volume levelis set to100.Go to
General playback optionsand turn offVolume normalization: it lowers the volume of louder tracks.Check the volume on your amplifier and, if you use one, on your DAC.
