Rivo Plus is the enhanced version of Rivo, our digital transport: a music streamer with no built-in DAC that sends a clean digital signal to an external DAC. Compared to Rivo, it adds an I2S over HDMI output for compatible high-end DACs and a 12V trigger output.
Rivo Plus - User manual (EN)Rivo Plus - User manual (IT)Specifications
AES/EBU (XLR) digital output, up to PCM 192 kHz/24 bit and DSD64 (DoP).
Coaxial S/PDIF digital output, up to PCM 192 kHz/24 bit and DSD64 (DoP).
I2S/DSD over HDMI digital output, up to PCM 768 kHz/32 bit and DSD256, with a pin assignment you can match to your DAC's brand.
Low-noise filtered USB output for an external USB DAC, up to PCM 768 kHz/32 bit and DSD256.
16 GB of internal memory, expandable with a microSD card.
Dimensions: 27 × 15 × 5 cm.
Connectivity
Gigabit Ethernet, dual-band Wi-Fi (2.4 and 5 GHz) and Bluetooth 5.0.
1 USB 2.0 port with low-noise filtering, dedicated to a USB DAC.
1 USB 3.0 port for fast drives such as SSDs, or CD drives.
1 USB 2.0 port for USB drives, keyboards, mice and smart remotes.
MicroSD card slot (SDSC/SDHC/SDXC), to add music files locally.
HDMI output to show the Volumio interface on a TV or monitor, up to 4K/60 fps.
12V trigger output (3.5 mm jack), to switch your other components on and off together with Rivo Plus.
5V DC power input.
In the box
Rivo Plus and a 5V/3A power supply with 4 plug adapters (EU, US, UK, AU/NZ).
