title: "Rivo Plus"
description: "Digital transport with I2S over HDMI and 12V trigger output."
url: https://help.volumio.com/en/articles/65-rivo-plus
collection: "User manuals"
updated: 2026-11-09
language: en
# Rivo Plus
![Front and rear views of the Volumio RIVO+ audio player show its blue front panel and labeled rear connections. Visible: RIVO+, VOLUMIO, USB, NET, Micro SD, HDMI.](https://staticfiles.gleap.io/ghelparticle/rJqGg8wRfumlILNIHbGI1OUZhdChQxNCslJzJ9ZMTorQSKWSasAVuBdX5d6AqUhgddPZ9W8v0TA.jpg)
Rivo Plus is the enhanced version of Rivo, our digital transport: a music streamer with no built-in DAC that sends a clean digital signal to an external DAC. Compared to Rivo, it adds an I2S over HDMI output for compatible high-end DACs and a 12V trigger output.
[**Rivo Plus** - User manual (EN)](https://heyzine.com/flip-book/8189006da2.html)[**Rivo Plus** - User manual (IT)](https://heyzine.com/flip-book/6fd02234c2.html)
## Specifications
-   AES/EBU (XLR) digital output, up to PCM 192 kHz/24 bit and DSD64 (DoP).
-   Coaxial S/PDIF digital output, up to PCM 192 kHz/24 bit and DSD64 (DoP).
-   I2S/DSD over HDMI digital output, up to PCM 768 kHz/32 bit and DSD256, with a pin assignment you can match to your DAC's brand.
-   Low-noise filtered USB output for an external USB DAC, up to PCM 768 kHz/32 bit and DSD256.
-   16 GB of internal memory, expandable with a microSD card.
-   Dimensions: 27 × 15 × 5 cm.
### Connectivity
-   Gigabit Ethernet, dual-band Wi-Fi (2.4 and 5 GHz) and Bluetooth 5.0.
-   1 USB 2.0 port with low-noise filtering, dedicated to a USB DAC.
-   1 USB 3.0 port for fast drives such as SSDs, or CD drives.
-   1 USB 2.0 port for USB drives, keyboards, mice and smart remotes.
-   MicroSD card slot (SDSC/SDHC/SDXC), to add music files locally.
-   HDMI output to show the Volumio interface on a TV or monitor, up to 4K/60 fps.
-   12V trigger output (3.5 mm jack), to switch your other components on and off together with Rivo Plus.
-   5V DC power input.
### In the box
Rivo Plus and a 5V/3A power supply with 4 plug adapters (EU, US, UK, AU/NZ).
