SSH lets you control your device from a computer's terminal. It's off by default, and you only need it for advanced tasks, or if our support team asks you to turn it on.
Turn on SSH
On a computer on the same network as your device, open a web browser.
Type your device's name followed by
.local/dev, for examplehttp://motivo.local/dev. If it doesn't work, use the device's IP address instead, for examplehttp://192.168.1.20/dev. To find both, see Volumio in a browser.Under
SSH, pressENABLE.
The page doesn't show any message, but SSH is on right away, and stays on even after a restart.
To turn it off, press DISABLE on the same page.
Connect to your device
On your computer, open the terminal:
On Mac:
Terminal.On Windows:
Command PromptorPowerShell.On Linux: any terminal.
Type
ssh volumio@followed by your device's IP address, for examplessh [email protected], and press Enter.Type the password
volumioand press Enter. The password doesn't show while you type.
Turn on SSH before the first start (DIY)
If you install Volumio on a Raspberry Pi and can't open the device in a browser, you can turn on SSH from the SD card:
Put the SD card with Volumio into your computer.
In the
bootpartition, create an empty file calledssh, with no extension.Put the SD card back into the Raspberry Pi and turn it on.
