Integro is our integrated network amplifier: a music streamer and a dual mono Class D power amplifier in one chassis, with a headphone amplifier on the front. Connect your passive speakers to it to play your music services, your local library and internet radio. You can also connect your turntable (through a phono preamp), CD player or TV to its analog and digital inputs.
Integro - User manual (EN)Integro - User manual (IT)Specifications
Amplifier: direct-digital dual mono Class D, based on two Infineon MA12070P.
Power output: 2 × 50 W RMS into 8 Ω, 2 × 70 W RMS into 4 Ω.
Playback up to PCM 192 kHz/24 bit.
Headphone output: Class AB amplifier (TI TPA6120A2) on a front 6.3 mm jack, 2 × 300 mW RMS into 64 Ω and 2 × 480 mW into 32 Ω.
Subwoofer output: mono line-out at 2 Vrms.
Coaxial and optical S/PDIF inputs up to PCM 192 kHz/24 bit.
Analog line input, sampled at 192 kHz/24 bit.
1.3" OLED display showing the selected source and the volume level.
Left knob: press to switch on/off, turn to select the source. Right knob: press to mute, turn to adjust the volume.
Dimensions: 27 × 15 × 5 cm.
Connectivity
Gigabit Ethernet and Wi-Fi 802.11a/b/g/n/ac (2×2 MIMO).
Bluetooth 5.0 input with aptX and aptX Low Latency.
Speaker terminals for the left and right speakers.
Analog RCA input, for a turntable (with phono preamp), a tuner or a CD player.
Coaxial and optical (TOSLINK) S/PDIF digital inputs, for a TV, a CD or Blu-ray player or a digital tuner.
RCA subwoofer output, for a powered subwoofer.
1 USB 3.0 and 1 USB 2.0 port, for USB drives, CD drives, keyboards and mice.
MicroSD card slot (SDSC/SDHC/SDXC), to add music files locally.
HDMI output to show the Volumio interface on a TV or monitor, up to 4K.
In the box
Volumio Integro and a 24V/6A power supply with 4 plug adapters (EU, US, UK, AU/NZ).
