title: "Integro"
description: "Integrated network amplifier with headphone output, for passive speakers."
url: https://help.volumio.com/en/articles/69-integro
collection: "User manuals"
updated: 2026-10-26
language: en
# Integro
![Front and rear panels of the INTEGRO VOLUMIO audio unit, showing its volume display and speaker, network, USB, and audio connections. Visible: INTEGRO, VOLUMIO, 52, SPEAKER RIGHT, USB, NET.](https://staticfiles.gleap.io/ghelparticle/xLa6AIafJXSPZvPXKQARyFgUpSvUHU3Bhgsk5XRyWD17KpqO1fLDMRJCNXxMCbMlKcUDgUfheKy.jpg)
Integro is our integrated network amplifier: a music streamer and a dual mono Class D power amplifier in one chassis, with a headphone amplifier on the front. Connect your passive speakers to it to play your music services, your local library and internet radio. You can also connect your turntable (through a phono preamp), CD player or TV to its analog and digital inputs.
[**Integro** - User manual (EN)](https://heyzine.com/flip-book/7710fd7468.html)[**Integro** - User manual (IT)](https://heyzine.com/flip-book/d0dacdd4e4.html)
## Specifications
-   Amplifier: direct-digital dual mono Class D, based on two Infineon MA12070P.
-   Power output: 2 × 50 W RMS into 8 Ω, 2 × 70 W RMS into 4 Ω.
-   Playback up to PCM 192 kHz/24 bit.
-   Headphone output: Class AB amplifier (TI TPA6120A2) on a front 6.3 mm jack, 2 × 300 mW RMS into 64 Ω and 2 × 480 mW into 32 Ω.
-   Subwoofer output: mono line-out at 2 Vrms.
-   Coaxial and optical S/PDIF inputs up to PCM 192 kHz/24 bit.
-   Analog line input, sampled at 192 kHz/24 bit.
-   1.3" OLED display showing the selected source and the volume level.
-   Left knob: press to switch on/off, turn to select the source. Right knob: press to mute, turn to adjust the volume.
-   Dimensions: 27 × 15 × 5 cm.
### Connectivity
-   Gigabit Ethernet and Wi-Fi 802.11a/b/g/n/ac (2×2 MIMO).
-   Bluetooth 5.0 input with aptX and aptX Low Latency.
-   Speaker terminals for the left and right speakers.
-   Analog RCA input, for a turntable (with phono preamp), a tuner or a CD player.
-   Coaxial and optical (TOSLINK) S/PDIF digital inputs, for a TV, a CD or Blu-ray player or a digital tuner.
-   RCA subwoofer output, for a powered subwoofer.
-   1 USB 3.0 and 1 USB 2.0 port, for USB drives, CD drives, keyboards and mice.
-   MicroSD card slot (SDSC/SDHC/SDXC), to add music files locally.
-   HDMI output to show the Volumio interface on a TV or monitor, up to 4K.
### In the box
Volumio Integro and a 24V/6A power supply with 4 plug adapters (EU, US, UK, AU/NZ).
