A factory reset brings your device back to how it was when it left the factory. Use it as a last resort, when nothing else fixes an issue.
From Settings
Open your device and go to
Settings→System.Under
System updates, pressFactory resetand confirm.
Help & support → Reset device: it takes you straight to your device's Settings.With a USB drive
Use this when the device doesn't start or you can't reach it from the app.
Download the factory reset file or create a new file called
factory_reset(no extension) containing only the textfactory_reset.Format a USB drive in
FAT32and copy thefactory_resetfile into it.Turn off the device.
Insert the USB drive.
Turn on the device.
The factory_reset file is erased from the USB drive once the reset is complete.
After the reset
Open the app: your device shows up as a new device. Tap
Setupand follow the steps to set it up again.On a Volumio device, or with Volumio Premium, sign in to MyVolumio to get back your playlists, favorites and web radios.
If your music is on a network drive, add it again.
Go to
Settings→Sources→My musicand pressUpdate libraryto find your music again.
