The screen settings are in your device's Settings → System → Video output options. In the app, open your device and go to Settings.
The screen shows nothing, or only the startup screen
Check that the screen is on and set to the HDMI input the device is connected to.
Go to
Settings→System→Video output optionsand check thatUser interface via HDMIis on, then pressSave.Restart the device with the screen already on and connected.
Try another HDMI cable.
The interface is too big, too small or cut off
Go to
Settings→System→Video output options.Change
Display zoom factor: a lower value fits more on the screen, a higher one makes everything bigger.Press
Save.
A touchscreen doesn't show the interface (DIY)
Check that the screen is supported and connected as its maker explains.
Go to
Settings→System→Video output optionsand check thatUser interface via HDMIis on.Restart the device.
Show mouse pointer in the same section.Still not working
Report a bug from the app with the screen connected, and tell us its brand and model and how it's connected.
