This article covers the settings in the app. To see which inputs and outputs your device has and how to connect them, see its user manual.
Choose the audio output
The audio output is where your device sends the sound: for example its analog outputs, a digital output, or a USB DAC.
Open your device and go to
Settings→Playback options.Under
Audio output, choose the output inOutput device.Press
Save.
The list shows the outputs of your device, plus any USB DAC connected to it. Some devices handle their outputs by themselves: on those, this setting isn't shown.
I2S DAC in the same section and choose your board in DAC model. More in DIY.Switch input
On devices with hardware inputs (for example optical, coaxial or analog), you can listen to what's connected to them, like a TV or a CD player.
Choose the input in one of these ways:
In
Browse, underInputs, press the input you want.In the player bar, tap
Inputs and outputs, then choose the input underInput source.Use the input knob or button on the device, or the remote control, as explained in its user manual.
To go back to Volumio's music, start playing anything from Browse: the device switches back by itself.
Volume
You can change the volume, or let your amplifier handle it.
Troubleshooting
There's no sound from the output
Go to
Settings→Playback optionsand check thatOutput deviceis the output your amplifier or DAC is connected to.Check that the amplifier or DAC is on and set to the right input.
For more, see Playback issues and DAC issues.
The inputs don't show up
Inputs only shows on devices with hardware inputs: check in your device's user manual which inputs it has.
