title: "Inputs and outputs"
description: "How to choose where your Volumio device sends its sound, and how to switch to its hardware inputs from the app."
url: https://help.volumio.com/en/articles/175-inputs-and-outputs
collection: "Getting started"
updated: 2026-11-13
language: en
# Inputs and outputs
This article covers the settings in the app. To see which inputs and outputs your device has and how to connect them, see its [user manual](https://help.volumio.com/collections/3-user-manuals).
## Choose the audio output
The audio output is where your device sends the sound: for example its analog outputs, a digital output, or a USB DAC.
1.  Open your device and go to `Settings` → `Playback options`.
2.  Under `Audio output`, choose the output in `Output device`.
3.  Press `Save`.
The list shows the outputs of your device, plus any USB DAC connected to it. Some devices handle their outputs by themselves: on those, this setting isn't shown.
> **Tip:** If you use a Raspberry Pi with an I2S DAC board (HAT), turn on `I2S DAC` in the same section and choose your board in `DAC model`. More in [DIY](https://help.volumio.com/articles/192-diy).
## Switch input
On devices with hardware inputs (for example optical, coaxial or analog), you can listen to what's connected to them, like a TV or a CD player.
Choose the input in one of these ways:
-   In `Browse`, under `Inputs`, press the input you want.
-   In the player bar, tap `Inputs and outputs`, then choose the input under `Input source`.
-   Use the input knob or button on the device, or the remote control, as explained in its user manual.
To go back to Volumio's music, start playing anything from `Browse`: the device switches back by itself.
## Volume
You can [change the volume](https://help.volumio.com/articles/178-volume), or let your amplifier handle it.
## Troubleshooting
### There's no sound from the output
1.  Go to `Settings` → `Playback options` and check that `Output device` is the output your amplifier or DAC is connected to.
2.  Check that the amplifier or DAC is on and set to the right input.
For more, see [Playback issues](https://help.volumio.com/articles/198-playback-issues) and [DAC issues](https://help.volumio.com/articles/203-dac-issues).
### The inputs don't show up
`Inputs` only shows on devices with hardware inputs: check in your device's user manual which inputs it has.
## Related
- [Nova and Volumio 4](https://help.volumio.com/en/articles/172-nova-and-volumio-4.md)
- [Volumio app](https://help.volumio.com/en/articles/173-volumio-app.md)
- [Volumio in a browser](https://help.volumio.com/en/articles/174-volumio-in-a-browser.md)
- [Power and standby](https://help.volumio.com/en/articles/176-power-and-standby.md)
- [Play music](https://help.volumio.com/en/articles/177-play-music.md)
