Primo V2 is the second generation of Primo, our music network player and streamer with a built-in high-resolution DAC. Connect it to your amplifier or active speakers, or send its digital signal to an external DAC, to play music services, your local library and internet radio.
Primo V2 - User manual (EN)Specifications
DAC: ESS Sabre ES9038Q2M.
Balanced XLR output at 4 Vrms.
Unbalanced RCA output at 2 Vrms.
Analog outputs play up to PCM 192 kHz/24 bit and DSD128 via DoP.
Coaxial S/PDIF output up to PCM 192 kHz/24 bit.
USB output for an external USB DAC, up to PCM 768 kHz/32 bit and DSD512.
CPU: Amlogic S905D3, quad-core Cortex-A55 at 1.9 GHz.
2 GB RAM and 16 GB of eMMC internal memory.
Dimensions: 27 × 15 × 5 cm.
Connectivity
Gigabit Ethernet and Wi-Fi 802.11a/b/g/n/ac (2×2 MIMO, internal antennas).
Bluetooth 5.0 input.
1 USB 3.0 port, for USB DACs, fast drives such as SSDs, or CD drives.
1 USB 2.0 port, for USB drives, keyboards, mice and smart remotes.
MicroSD card slot (SDSC/SDHC/SDXC), to add music files locally.
HDMI output to show the Volumio interface on a TV or monitor, up to 4K/60 fps.
5V DC power input.
In the box
Primo V2 and a 5V/3A power supply with 4 plug adapters (EU, US, UK, AU/NZ).
