With multiroom, you group two or more Volumio devices on your network, and they play the same music at the same time. One device is the group leader: it plays the music and sends it to the others.
Multiroom is a Premium feature: it's included on Volumio devices, and needs a Premium plan on Raspberry Pi and PC.
Before you start
All devices must be on the same network.
All devices must be on the same Volumio version: update them all first.
Group your devices
Open the device you want to play the music from, and start playing.
In the player, tap
⋮→Multiroom zones. You can also open it fromInputs and outputsin the player bar.In
Zones, tap the options button next to another device and chooseGroup with (name).Repeat for every device you want in the group.
The device you play from shows group leader, the others show grouped. Control the music from the group leader: the others follow it.
Control the group
In Zones:
Use the volume slider next to each device to set its own volume.
To take a device out of the group, tap its options button and choose
Ungroup.To end the group, tap
Disband groupon the group leader.
This device is playing in sync with a group, you can't control it on its own: ungroup it in Zones first.Troubleshooting
The music skips or stops on some devices
Connect the devices with an Ethernet cable, or move them closer to the router.
On the group leader, go to
Settings→Sources→My music→Music sourcesand press the settings button next toMultiroom playback.Under
Server configuration, setBuffer (all clients)to2000ms slow responsiveness (higher quality). If it still skips, setStream buffer (all clients)to100ms slow networksor200ms slow networks.Press
Save.
A bigger buffer makes the music more stable, but it takes a bit longer to start after you press play.
The devices aren't perfectly in sync
Some DACs and amplifiers add a small delay. On the device that plays late:
Go to
Client configuration, enter the delay in milliseconds inHardware latency, for example50.Press
Saveand listen again. Change the value until the devices play together.
A device doesn't show up in Zones
Check that the device is on, and on the same network.
On that device, go to
Settings→Sources→My music→Music sourcesand check thatMultiroom playbackis on.Check that it's on the same Volumio version as the others.
Restart the device.
DSD and Hi-Res files in multiroom
In multiroom, the music is sent to every device at CD-like quality (48 kHz, 16 bit), whatever the file. DSD files may not play in a group: play them on a single device.
The group doesn't respond, or devices play out of step
Tap Disband group on the group leader, then group the devices again. If it keeps happening, restart all the devices.
