title: "Multiroom"
description: "How to play the same music in sync on several Volumio devices, control the group, and fix music that skips or drifts."
url: https://help.volumio.com/en/articles/190-multiroom
collection: "Getting started"
updated: 2026-11-13
language: en
# Multiroom
With multiroom, you group two or more Volumio devices on your network, and they play the same music at the same time. One device is the group leader: it plays the music and sends it to the others.
Multiroom is a [Premium feature](https://help.volumio.com/articles/205-volumio-free-vs-premium): it's included on Volumio devices, and needs a Premium plan on Raspberry Pi and PC.
## Before you start
-   All devices must be on the same network.
-   All devices must be on the same Volumio version: [update them all](https://help.volumio.com/articles/193-update-your-device) first.
> **Tip:** If you can, connect the devices with an Ethernet cable: multiroom needs a steady network, and Wi-Fi drops can make the music skip.
## Group your devices
1.  Open the device you want to play the music from, and start playing.
2.  In the player, tap `⋮` → `Multiroom zones`. You can also open it from `Inputs and outputs` in the player bar.
3.  In `Zones`, tap the options button next to another device and choose `Group with (name)`.
4.  Repeat for every device you want in the group.
The device you play from shows `group leader`, the others show `grouped`. Control the music from the group leader: the others follow it.
## Control the group
In `Zones`:
-   Use the volume slider next to each device to set its own volume.
-   To take a device out of the group, tap its options button and choose `Ungroup`.
-   To end the group, tap `Disband group` on the group leader.
> **Tip:** If a grouped device shows `This device is playing in sync with a group`, you can't control it on its own: ungroup it in `Zones` first.
## Troubleshooting
### The music skips or stops on some devices
1.  Connect the devices with an Ethernet cable, or move them closer to the router.
2.  On the group leader, go to `Settings` → `Sources` → `My music` → `Music sources` and press the settings button next to `Multiroom playback`.
3.  Under `Server configuration`, set `Buffer (all clients)` to `2000ms slow responsiveness (higher quality)`. If it still skips, set `Stream buffer (all clients)` to `100ms slow networks` or `200ms slow networks`.
4.  Press `Save`.
A bigger buffer makes the music more stable, but it takes a bit longer to start after you press play.
### The devices aren't perfectly in sync
Some DACs and amplifiers add a small delay. On the device that plays late:
1.  Go to `Settings` → `Sources` → `My music` → `Music sources` and press the settings button next to `Multiroom playback`.
2.  Under `Client configuration`, enter the delay in milliseconds in `Hardware latency`, for example `50`.
3.  Press `Save` and listen again. Change the value until the devices play together.
### A device doesn't show up in Zones
1.  Check that the device is on, and on the same network.
2.  On that device, go to `Settings` → `Sources` → `My music` → `Music sources` and check that `Multiroom playback` is on.
3.  Check that it's on the same Volumio version as the others.
4.  Restart the device.
### DSD and Hi-Res files in multiroom
In multiroom, the music is sent to every device at CD-like quality (48 kHz, 16 bit), whatever the file. DSD files may not play in a group: play them on a single device.
### The group doesn't respond, or devices play out of step
Tap `Disband group` on the group leader, then group the devices again. If it keeps happening, restart all the devices.
## Related
- [Nova and Volumio 4](https://help.volumio.com/en/articles/172-nova-and-volumio-4.md)
- [Volumio app](https://help.volumio.com/en/articles/173-volumio-app.md)
- [Volumio in a browser](https://help.volumio.com/en/articles/174-volumio-in-a-browser.md)
- [Inputs and outputs](https://help.volumio.com/en/articles/175-inputs-and-outputs.md)
- [Power and standby](https://help.volumio.com/en/articles/176-power-and-standby.md)
