Primo V3 is the third generation of Primo, our streaming DAC: a music streamer with a built-in high-quality DAC, completely redesigned around our latest platform. Connect it to your amplifier or active speakers to enjoy your music services, your local library and internet radio in high resolution.
Primo V3 - User manual (EN)Specifications
DAC: ESS Sabre ES9039Q2M, with 8 digital filters and switchable NOS mode.
Playback up to PCM 384 kHz/32 bit.
Balanced XLR output with 8 selectable levels, from 1.0 to 6.3 Vrms.
Unbalanced RCA output with 8 selectable levels, from 0.5 to 3.15 Vrms.
USB output for an external USB DAC, up to PCM 1536 kHz/32 bit and DSD1024.
Internal linear power supply stage and ultra-low phase noise master clock.
Dimensions: 27 × 15 × 5 cm.
Connectivity
2 USB-A 2.0 ports for USB drives and external DACs.
HDMI output to show the Volumio interface on a TV or monitor, up to 4K/60 fps.
Gigabit Ethernet, dual-band Wi-Fi (2.4 and 5 GHz) and Bluetooth 5.0.
12V trigger output, to switch your other components on and off together with Primo V3.
In the box
Primo V3 and a 5V/3A power supply with 4 plug adapters (EU, US, UK, AU/NZ).
