title: "Remoto"
description: "Aluminium IR remote control for compatible Volumio devices."
url: https://help.volumio.com/en/articles/72-remoto
collection: "User manuals"
updated: 2026-10-31
language: en
# Remoto
![A silver Volumio remote control with black buttons is shown on a white background. Visible: Volumio.](https://staticfiles.gleap.io/ghelparticle/XkYpKQSYYUHLAbBnPdHU9euWR29DN4VwfMGAYdkXqVATOAD6novxypsWntRao4NyGwgdC82nJNw.jpg)
Remoto is our infrared remote control, with a solid aluminium body. Use it to control the volume, input selection, playback and DAC filter settings of compatible Volumio devices.
[**Remoto** - User manual (EN)](https://heyzine.com/flip-book/7f337068ef.html)
## Specifications
-   Aluminium body with silver anodized finish.
-   Buttons: power, mute, volume down/up, play/pause, input select, previous and next track.
-   Power: 1 CR2032 battery. Remove the plastic strip from the battery compartment before first use.
-   Dimensions: 12.2 × 3.6 × 0.8 cm.
### Connectivity
-   Infrared, with no pairing or setup needed.
### In the box
Remoto and 1 CR2032 battery.
> **Success:** Remoto **IS** compatible with the following Volumio devices:
> Preciso, Primo Plus.
> **Error:** Remoto **IS NOT** compatible with the following Volumio devices:
> Integro, Motivo, Primo V2, Primo V3, Rivo, Rivo Plus.
