title: "Rivo Ultra"
description: "Flagship digital transport with 12\" touchscreen, linear power supply and NVMe slot for your music."
url: https://help.volumio.com/en/articles/215-rivo-ultra
collection: "User manuals"
updated: 2026-11-18
language: en
# Rivo Ultra
Flagship digital transport with 12" touchscreen, linear power supply and NVMe slot for your music.
![Rivo Ultra](https://staticfiles.gleap.io/p69c24ae03f50abbb1f60bd70/YcPSYQkTu013uH18TFFYvZmEEz4dZZd7L3XetdUyQo3u5txjq2BbPr06yF11Qba0vRfJnbYRVcK.jpg)
Rivo Ultra is our flagship digital transport: a music streamer with no built-in DAC that sends a clean, low-jitter digital signal to an external DAC. Compared to Rivo Plus, it adds a 12" touchscreen, a built-in linear power supply, optical and BNC outputs, and a slot for an internal SSD to hold your music library.
[**Rivo Ultra** - User manual (EN)](https://heyzine.com/flip-book/7906162449.html)
## Specifications
-   USB output for an external USB DAC, up to PCM 1536 kHz/32 bit and DSD1024 (DSD256 with multiroom on), with power filtering and volume control on compatible DACs.
-   I2S/DSD over HDMI digital output, up to PCM 768 kHz/32 bit and DSD1024 (DSD256 with multiroom on), with a pin assignment you can match to your DAC's brand.
-   AES/EBU (XLR) digital output, up to PCM 192 kHz/24 bit and DSD64 (DoP).
-   Coaxial S/PDIF digital outputs (RCA and BNC), up to PCM 192 kHz/24 bit and DSD64 (DoP).
-   2 optical S/PDIF digital outputs (TOSLINK), up to PCM 192 kHz/24 bit and DSD64 (DoP).
-   Femto clock (54 fs) for the built-in outputs, and a temperature-compensated clock for the USB output.
-   Built-in dual linear power supply with a toroidal transformer.
-   16 GB of internal memory, plus a slot for an NVMe SSD up to 16 TB.
-   12" touchscreen and a volume knob with its own display, both with adjustable brightness.
-   Finishes: full aluminum, or aluminum with a leather top.
-   Dimensions: 44 × 34 × 9 cm.
### Connectivity
-   Gigabit Ethernet, dual-band Wi-Fi (2.4 and 5 GHz) and Bluetooth 5.0.
-   1 USB 2.0 port dedicated to a USB DAC.
-   3 USB 3.0 ports and 1 USB-C port, for USB drives, SSDs or CD drives.
-   AES/EBU (XLR), coaxial (RCA and BNC) and 2 optical (TOSLINK) S/PDIF digital outputs.
-   I2S/DSD over HDMI digital output, for an external DAC.
-   HDMI output to show the Volumio interface on a TV or monitor, up to 4K/60 fps.
-   12V trigger output (3.5 mm jack), to switch your other components on and off together with Rivo Ultra.
-   IR receiver, for the included Volumio Remoto remote control.
-   AC power input (IEC C13), 115–230 V, with a voltage selector and 2 fuses.
### In the box
Rivo Ultra, Volumio Remoto, a Wi-Fi antenna and the power cord.
## Related
- [Integro](https://help.volumio.com/en/articles/69-integro.md)
- [Lineo5](https://help.volumio.com/en/articles/71-lineo5.md)
- [Lineo5 Duo](https://help.volumio.com/en/articles/164-lineo5-duo.md)
- [Motivo](https://help.volumio.com/en/articles/70-motivo.md)
- [Preciso](https://help.volumio.com/en/articles/66-preciso.md)
