title: "Lineo5 Duo"
description: "Dual-output linear power supply for two 5V Volumio devices."
url: https://help.volumio.com/en/articles/164-lineo5-duo
collection: "User manuals"
updated: 2026-11-06
language: en
# Lineo5 Duo
![Front and rear panels of the Volumio Lineo 5 Duo, showing its power button, audio connections, voltage selector, and power inlet. Visible: LINEO 5, VOLUMIO, DUO, VOLTAGE SELECTOR, 220V, WARNING.](https://staticfiles.gleap.io/ghelparticle/r1AvDytT8anyxxwfEqA3awKbZMRvDpmgmLn67I6hg1ydHWHicbWFgif7tp5rkwJwW7NnI3blnOj.jpg)
Lineo5 Duo is a dual-output linear power supply for Volumio electronics and other 5V audio devices. It replaces the external switching power supplies of two devices with two independent 5V outputs, for example Rivo+ and Preciso. Connect each device with one of the included GX-16 to DC barrel jack cables.
[**Lineo5 Duo** - User manual (EN)](https://heyzine.com/flip-book/5d00d6bc3f.html)
## Specifications
-   Output: 2 independent 5V DC outputs, 4A max each, with dedicated regulators and filtering.
-   Input voltage: switchable between 100-120V AC (50/60Hz) and 220-240V AC (50Hz).
-   Power consumption: 120W max at full output load.
-   Toroidal transformer with dual linear regulation.
-   Audio-grade low ESR capacitors, 40000µF total bulk capacitance.
-   Residual noise: 20µV.
-   Easy-to-access fuse.
-   Aluminum chassis with integrated heatsink.
-   Dimensions: 27 × 22.7 × 7.7 cm.
### Connectivity
-   DC outputs: two 2-pin GX-16 connectors.
-   Output cables: GX-16 to 5.5 × 2.1 mm DC barrel jack, tip positive.
-   AC input connector, with a voltage selector (110V/220V) on the back panel. Set it to your mains voltage before connecting to power.
-   Front power button and blue status LED, which lights when Lineo5 Duo is on.
### In the box
Lineo5 Duo, 4 AC cables (EU, US, UK, AU/NZ), and 2 GX-16 to DC barrel jack cables (5.5 × 2.1 mm, tip positive).
> **Success:** Lineo5 Duo **IS** compatible with the following Volumio devices:
> Preciso, Primo V2, Primo V3, Primo Plus, Rivo, Rivo Plus.
> **Error:** Lineo5 Duo **IS NOT** compatible with the following Volumio devices:
> Integro, Motivo.
