title: "Beta channel"
description: "How to get Volumio versions before their official release by switching your device to the beta channel, and how to go back."
url: https://help.volumio.com/en/articles/195-beta-channel
collection: "Getting started"
updated: 2026-11-13
language: en
# Beta channel
Your device gets updates from the stable channel: versions that have been fully tested. On the beta channel, you get new versions earlier, before they're released to everyone.
> **Warning:** Beta versions are still being tested and may have bugs. If you rely on your device every day, stay on the stable channel.
## Switch to the beta channel
1.  On a computer on the same network as your device, open a web browser.
2.  Type your device's name followed by `.local/dev`, for example `http://motivo.local/dev`. If it doesn't work, use the device's IP address instead, for example `http://192.168.1.20/dev`. To find both, see [Volumio in a browser](https://help.volumio.com/articles/174-volumio-in-a-browser).
3.  Under `Update Channel Selection`, choose `Test`.
4.  In the app, open your device and go to `Settings` → `System`, then press `Check updates` under `System updates` to [install the beta version](https://help.volumio.com/articles/193-update-your-device).
> **Tip:** If you want to stay on the beta channel, choose `Test` again after every update: once an update is installed, the device goes back to the stable channel.
## Go back to the stable channel
After a beta update, your device is already back on the stable channel, and gets the next stable version as usual.
If you chose `Test` but haven't updated yet, go to the same page and choose `Stable` under `Update Channel Selection`.
If you [report a problem](https://help.volumio.com/articles/33-report-a-bug) while you're on a beta version, tell us in your report.
## Related
- [Nova and Volumio 4](https://help.volumio.com/en/articles/172-nova-and-volumio-4.md)
- [Volumio app](https://help.volumio.com/en/articles/173-volumio-app.md)
- [Volumio in a browser](https://help.volumio.com/en/articles/174-volumio-in-a-browser.md)
- [Inputs and outputs](https://help.volumio.com/en/articles/175-inputs-and-outputs.md)
- [Power and standby](https://help.volumio.com/en/articles/176-power-and-standby.md)
