title: "TIDAL"
description: "How to connect your TIDAL account to your Volumio device, play from Volumio or the TIDAL app, and choose the sound quality."
url: https://help.volumio.com/en/articles/180-tidal
collection: "Getting started"
updated: 2026-11-13
language: en
# TIDAL
You can play TIDAL on your device in two ways:
-   From Volumio: browse and search TIDAL in `Browse` → `TIDAL`.
-   From the TIDAL app: pick your device as the speaker with TIDAL Connect.
You need a TIDAL subscription. TIDAL is a [Premium feature](https://help.volumio.com/articles/205-volumio-free-vs-premium): it's included on Volumio devices, and needs a Premium plan on Raspberry Pi and PC.
## Connect your TIDAL account
1.  Open your device and go to `Settings` → `Sources`.
2.  Under `TIDAL`, press `Connect`.
3.  Sign in to TIDAL in the page that opens and allow access.
When you're back, TIDAL shows up in `Browse`.
To disconnect your account, press `Logout` in the same section.
## Play from the TIDAL app
1.  Connect your phone to the same network as your device.
2.  Open the TIDAL app, start a song, tap the devices button and choose your device.
> **Tip:** If your device doesn't show up in the TIDAL app, go to `Settings` → `Sources` → `My music` → `Music sources` and check that `Tidal connect` is on.
## Choose the sound quality
1.  Go to `Settings` → `Sources`, below `TIDAL`.
2.  In `Sound quality`, choose the quality you want, or `Highest possible` to always get the best one.
3.  Press `Save`.
`Sound quality` only applies when you play from Volumio. With TIDAL Connect, choose the quality in the TIDAL app's settings.
In the same section, `Number of search results` sets how many results TIDAL shows when you search.
## Troubleshooting
### The quality is lower than expected
Tap the quality badge on the player: `Audio quality` shows what your device is actually playing.
1.  Check that your TIDAL plan includes the quality you want.
2.  Playing from Volumio: check `Sound quality` in `Settings` → `Sources`, and press `Save`.
3.  Playing from the TIDAL app: check the streaming quality in the TIDAL app's settings.
4.  Not every song is available in Hi-Res: the quality depends on each song.
5.  Your device or DAC may not support the highest qualities: in that case, the music plays at the best quality they support.
For other issues, such as TIDAL not showing up or not signing in, see [Streaming service issues](https://help.volumio.com/articles/200-streaming-service-issues).
## Related
- [Nova and Volumio 4](https://help.volumio.com/en/articles/172-nova-and-volumio-4.md)
- [Volumio app](https://help.volumio.com/en/articles/173-volumio-app.md)
- [Volumio in a browser](https://help.volumio.com/en/articles/174-volumio-in-a-browser.md)
- [Inputs and outputs](https://help.volumio.com/en/articles/175-inputs-and-outputs.md)
- [Power and standby](https://help.volumio.com/en/articles/176-power-and-standby.md)
