Volumio Knowledge Base VOLUMIO USER GUIDE Current: Setting tips Setting tips Find here useful tips on how to setup your Volumio device How to select the Mixer output? What is the resampling and which sources does it affect? How to switch from UI layouts? What is the hotspot network? Which is the best wifi network connection to select? When the Factory Reset of the unit is requested? How to connect NAS drive via SMB protocol? How to connect an HDD/SSD to Volumio? How does Analog RCA output DSP option work? [Volumio Primo] How to setup Multiroom in the better way? How to setup DSD playback options? How to link a streaming service account? How to connect NAS drive via DLNA media server protocol? Which is the better choice to select the audio output? How to connect a PC as media server? How to mount a MAC share folder? How does resampling function work? ×
