Volumio can be updated via USB. This is useful in cases like unavailability of internet connection or a critical update.
To update via USB:
  • Download the appropriate update file for your device
UPDATE FOR INTEGRO
https://updates.volumio.org/mp1/integro/latest/update.fir
UPDATE FOR RIVO
https://updates.volumio.org/mp1/rivo/latest/update.fir
UPDATE FOR PRIMO2
https://updates.volumio.org/mp1/primo2rev2/latest/update.fir
  • Turn off your device
  • Get a USB thumb drive, or USB Hard Drive
NOTE: The drive must be formatted in FAT32
  • Copy the update file on the drive
  • Plug the drive into the device
  • Turn the device on
  • The update will take approximately 10 minutes
  • Once the device has restarted, remove the USB drive
  • If the update has been performed correctly, the update file will not be on the drive anymore
