To do before:
To do next:
Note: no Master group volume control available ; it's not possible to create group between devices on different networks
Your music is not perfectly synchronized?
Go to SOURCES→MULTIROOM→SETTINGS
increase the hardware latency in msec unit, of the relate device
adjust the buffer size in msec unit (in case your hardware/network connection is not performant). This will delay all the network devices
