Skip to main content
How to setup Multiroom in the better way?
To do before:
  • We suggest the ethernet cable connection, at least from the Master group device to the router (if it’s not possible use the 5GHz network as preference)
To do next:
  • Click on the MULTIROOM icon on the top right corner of the User Interface
  • Click on GROUP DEVICES
  • Click on ADD to add the selected device to the group
Note: no Master group volume control available ; it's not possible to create group between devices on different networks
Your music is not perfectly synchronized?
Go to the Multiroom client User interface
Go to SOURCES→MULTIROOM→SETTINGS
  • increase the hardware latency in msec unit, this will delay all the other devices, in the same multiroom group, among the selected client device
  • adjust the buffer size in msec unit (in case your hardware/network connection is not performant). This will delay all the client devices
JavaScript errors detected
