Rivo is a pure digital streamer, technically called DIGITAL TRANSPORT.
It allows you to stream digital sources perfectly to an external DAC, without filters, straight to its digital outputs, optimizing the high resolution audio in terms of detail, cleaning of the signal path and definitely a better signal processing
