Volumio Knowledge Base VOLUMIO TROUBLESHOOTINGS Current: Volumio device is no longer wi-fi recognized in the local network Volumio device is no longer wi-fi recognized in the local network Check inside your router’s settings if Volumio device is properly recognizedIf not, connect via Ethernet cable the unit to the router ethernet portCheck now again inside the router’s settings to reach the Volumio IP addressDo a first check on WI-Fi settings, inside Volumio SETTINGS MENU-->NETWORK MENU Make sure the Wi-Fi network is enabledIn case the previous steps cannot help, do a FACTORY RESET to do FACTORY RESET: go to SETTINGS MENU-->FACTORY RESET (all the network settings, music libraries scans and setup settings will be deleted) ×
