Volumio APP is unresponsive, what are the possible causes?
- If the Volumio device and the remote controllers (smartphone, tablet, etc..) are connected to 5GHz WiFi network, make sure the wifi range is optimal for any device.
- Make sure only one connection among cable and WiFi is active. Multiple active connections, with different IP addresses, could create conflict on App recognition.
How to solve :
- Boost WiFi network with an WiFi range extender OR put powerline extenders between Volumio device and the router if the unit is anyway out of wireless range
- Switch all devices on 2.4GHz WiFi network. This connection has greater range.
- Switch off the unused connection from NETWORK MENU
