To play TIDAL on your Volumio device, you can use the TIDAL Connect feature*.
From the TIDAL app, go to the “Now Playing” page
Click on the device icon.
Choose your Volumio device (You will find it under the name you put to your device with the “TIDAL Connect” written below it).
*This feature is available for Premium users.
