1 ) In FusionDsp, all settings can be saved
in 5 custom presets.
2 ) Move to "save current settings" section
3 ) Choose in which preset you want
to save settings.
4 ) You can rename the preset
as you like
5 ) Then press "apply"
It's saved!
6 ) Now the new preset can be used.
Before, let's first reset settings to see that.
7 ) Go to the section "Use preset"
8 ) Choose the one you created
9 ) Press "Load and use"
10 ) Settings are restored!
