To redeem your coupon code for MyVolumio, complete the signup page and insert the code during check out according to the subscription type promotion.
Coupon code can only be inserted if your current MyVolumio plan is FREE.
When using a coupon code, trial period is skipped and you will be automatically charged the applicable Subscription fees for the type of Subscription you have selected.
