Volumio Knowledge Base VOLUMIO USER GUIDE VOLUMIO 3 SOFTWARE Browsing guide tips Player features How to use FusionDSP plugin? How to equalize headphones.. How to equalize headphones.. 1 ) FusionDsp is able to import Headphone equalizer settings directly from Autoeq2 ) Set the mode on Parametric Eq3 ) Scroll down to the section"Import Eq from Autoeq"4 ) Choose your headphone model in the list.It may take several second before it appears5 ) Click "import and load eq"It's done!6 ) You can see values loaded7 ) For your headphone, you can use a Crossfeed.FusionDsp provides 7 different Crossfeed.8 ) Click on "More settings"9 ) Choose the Crossfeed you want.10 ) Click on "Apply"11 ) Enjoy music! ×
