You can try MyVolumio Premium plan for 14 days for free and you are required to enter your billing information in order to sign up for the Free Trial.
On the last day of the Free Trial period, unless you cancelled your Subscription, you will be automatically charged the applicable Subscription fees.
If you use a coupon code, trial period is skipped and you will be immediately charged the applicable Subscription fees (deducting the coupon code discount amount).
