Skip to main content
Which is the better choice to select the audio output?
According to your Volumio device you can have ANALOG or DIGITAL OUTPUTS as audio output choices.
USB DAC: Attach an USB DAC (2.0 USB and up) using a high quality USB cable.
Suggested in particular for Tidal MQA hardware decoding and DSD native playback. Samplerate supported until 768KHz/32bit PCM.
USB DAC 5V low-noise filter [Volumio Rivo]: Dedicated port for a better clean digital audio signal, without power noise disturbances.
SPDIF [Volumio Primo and Volumio Rivo]: Attach a COAX digital DAC or Audio receiver. Samplerate supported until 192KHz/24bit PCM
ANALOG RCA [Volumio Primo]: Using the internal Primo’s DAC D/A converter go out from RCA OUTPUT and go in to the AMP/PRE AMP
I2S DAC/HAT: Connecting an I2S DAC/HAT to the compatible SBC board you will expand the audio outputs according to the I2S device connected. A long list of I2S drivers compatible inside PLAYBACK OPTION→I2S MENU
AES/EBU [Volumio Rivo]: Attach a digital balanced XLR cable. Samplerate supported until 192KHz/24bit PCM
JavaScript errors detected
