Skip to main content
Which Volumio Devices Can I Use with the Lineo5?
The Lineo5 linear power supply is designed to provide clean, stable power to enhance the performance of Volumio’s high-end audio components.
Compatible Devices:
  • Primo v2
  • Rivo
  • Rivo+
  • Preciso DAC
Using a splitter cable, the Lineo5 can power both the Preciso and a Rivo or Rivo+ simultaneously, making it a perfect match for stacked systems.
The Preciso DAC includes a built-in hardware volume control, allowing it to function as a preamp when connected to a power amplifier.
  • Volume is adjustable via the right knob on the front panel.
  • A dedicated remote control for Preciso will be made available if enough users express interest
JavaScript errors detected
