Skip to main content
How to select the Mixer output?
Volumio allows to select the best mixer preference according to your audio chain.
First:
  • Go to SETTINGS menu
  • Go to PLAYBACK OPTIONS menu
Here, you have 3 mixer choices:
  • Software: mixer algorithm is demanded to Volumio OS
  • Hardware: mixer algorithm is demanded to the streamer board (suggested if you are using Volumio Primo without external DAC)
  • None: mixer algorithm is demanded to an external DAC/AMP
JavaScript errors detected
