Skip to main content
How to connect your headphones to Motivo
https://www.loom.com/embed/64af6e10a330462eb7049fe75333f141?sid=c5975e51-4881-48e2-a24e-3934535907f7
To connect your headphones to your new Volumio device, Motivo, follow these steps:
Open Your Volumio App: Launch the Volumio app on your smartphone or tablet.
Tap on "Playback Option" in the top menu bar.
General Playback option: Within the Playback section, you'll find the "Output Device" option. Tap on it to activate “Analog + 12S + Headphones output”
Connect Your Headphones!
Motivo offers a choice of two 6.3mm headphone output sockets on its rear panel. The left headphone output is optimized to drive low-impedance headphones, the right output is optimized for high-impedance headphones.
PLEASE NOTE: Only one set of headphones should be connected at any time.
Start Playback: Once your headphones are connected, start playing music from your smartphone or tablet using Volumio.
JavaScript errors detected
