Skip to main content
How to connect your Volumio Motivo via Chromecast
https://www.loom.com/embed/b5fb4cbb49e441d3b7e3ee61b3456e45?sid=f85360a5-f480-493e-ba86-9dbfa6734c04
To connect your Volumio Motivo via Chromecast, follow these steps:
  • Setup Chromecast: Make sure your Chromecast device is set up and connected to the same Wi-Fi network as your Volumio Motivo.
  • Open Volumio App: Launch the Volumio app on your smartphone or tablet.
  • As shown in the video, clicl on the small speaker icon in the bottom right corner in the Volumio app.
  • Then Select Chromecast from the list of available devices.
  • Select the music you want to play from your library or any streaming service integrated with Volumio.
  • The audio should now be streaming to your Chromecast-enabled device.
  • Once the audio is streaming, you can control playback (play, pause, skip tracks, etc.) directly from the Volumio app on your smartphone or tablet.
Enjoy: Sit back and enjoy your music streaming through your Chromecast-connected audio system.
JavaScript errors detected
