Skip to main content
How to connect your Rivo+ via Chromecast
https://www.loom.com/share/b5fb4cbb49e441d3b7e3ee61b3456e45?sid=cd416e14-e3b1-4be5-9529-b3e742327a0b
To connect your Volumio Rivo+ via Chromecast, follow these steps:
  • Setup Chromecast: Make sure your Chromecast device is set up and connected to the same Wi-Fi network as your Volumio Rivo+.
  • Open Volumio App: Launch the Volumio app on your smartphone or tablet.
  • As shown in the video, clicl on the small speaker icon in the bottom right corner in the Volumio app.
  • Then Select Chromecast from the list of available devices.
  • Select the music you want to play from your library or any streaming service integrated with Volumio.
  • The audio should now be streaming to your Chromecast-enabled device.
  • Once the audio is streaming, you can control playback (play, pause, skip tracks, etc.) directly from the Volumio app on your smartphone or tablet.
Enjoy: Sit back and enjoy your music streaming through your Chromecast-connected audio system.
JavaScript errors detected
