Skip to main content
How to connect your Rivo+ via Bluetooth
https://www.loom.com/embed/2f2502b643194a79bbadfbb7a5ac9ea3?sid=51b2e4fb-f57b-48fd-8c4c-6f47ad5bc84e
To connect your new Rivo+ device, via Bluetooth, follow these steps:
Open Your Volumio App: Launch the Volumio app on your smartphone or tablet.
Navigate to Sources: In the app, tap on "Sources" in the top menu bar.
Select Bluetooth Input: Within the Sources section, you'll find the "Bluetooth Input Playback" option. Tap on it to connect Rivo+ to your Bluetooth-enabled device.
Start Playback: Once you've selected Bluetooth Input, Rivo+ will become discoverable as a Bluetooth device. Pair your smartphone or tablet with Rivo+ by selecting it from the list of available devices.
Enjoy Your Music: Once paired, you can start playing music from your smartphone or tablet, and it will be streamed to Rivo+via Bluetooth.
JavaScript errors detected
