Skip to main content
How to Connect a Denafrips DAC to Volumio Rivo+ via I2S
What You Need
  • Volumio Rivo+
  • Denafrips DAC with I2S (HDMI) input
  • HDMI cable for I2S connection
Step 1: Connect the Hardware
  1. Power off both Rivo+ and the Denafrips DAC
  2. Connect the I2S (HDMI) output of Rivo+ to the I2S input of the Denafrips DAC
  3. Power on the DAC first, then the Rivo+
Step 2: Set the Correct I2S Configuration on the Denafrips DAC
By default, Denafrips DACs may not use the correct I2S pin layout for Rivo+, which can cause:
  • Very distorted or screeching sound
  • Audio that sounds “broken”
  • Incorrect left/right channel playback
To fix this, you must change the DAC I2S mode.
Required setting:
  • I2S Mode: 5
  • LED sequence: 1 – 0 – 1
This aligns the DATA, BCK, and LRCK signals correctly with Rivo+.
Step 3: How to Change the I2S Mode
Follow the official Denafrips instructions here:
https://www.denafrips.com/config-pontus
After setting Mode 5:
  • Restart the Denafrips DAC
  • Restart the Rivo+
Step 4: Select Output in Volumio
  1. Open Volumio UI
  2. Go to Settings → Playback Options
  3. Select I2S / HDMI output
  4. Start playback
Important Notes
  • This applies only when using I2S
  • USB and S/PDIF connections do not require this configuration
  • This is not a fault of Rivo+ or the DAC
  • Once set, no further changes are needed
Summary
If a Denafrips DAC sounds distorted when connected to Rivo+ via I2S:
  • Set the DAC to I2S Mode 5
  • Confirm LED sequence = 1 – 0 – 1
  • Restart both devices
This ensures full compatibility and correct sound reproduction.
JavaScript errors detected
