Skip to main content
How can I upgrade from Volumio 3 to Volumio 4?
You can't update over the air from Volumio 3 to Volumio 4. You'll need to reflash the IMG. It's not ideal, but with a change this fundamental, it was the only way to ensure everything works correctly.
JavaScript errors detected
