Skip to main content
CD Ripping Not Working?
If you are experiencing issues with CD ripping, please try the following steps to resolve the problem:
  1. Use a Powered USB Hub: Connect your CD drive to a powered USB hub. Sometimes, the CD drive may not receive sufficient power from your device’s USB port, which can cause issues with the ripping process.
  2. Check Power Supply: Ensure that the CD drive is properly connected and receiving enough power. Insufficient power can prevent the CD drive from functioning correctly during ripping.
  3. Verify Connections: Make sure all cables are securely connected to both the CD drive and the powered USB hub.
  4. Restart Your Device: Sometimes, restarting your device can help resolve connectivity issues with the CD drive.
  5. Update Software: Ensure that you have the latest version of the Volumio software. Updates often include fixes and improvements that can resolve hardware compatibility issues.
  6. Try a Different USB Port: If you are not using a powered USB hub, try connecting the CD drive to a different USB port on your device.
If these steps do not resolve the issue, please contact our support team for further assistance. You can reach us here.
JavaScript errors detected
